Turbo 1.2
AP7
My turbo on my 1.2 auris 2016 seems to stutter had new sparks put in but still same problem
We stopped using dead animal bones to find out what's actually wrong with people cars, some time ago.
I'm afraid you'd have to describe the problem in greater detail.
  • Haha 3
Funny 😄 but true., well said Dean 👍
When accelerating in 2&3 gear around 3000 rpm the engine jolts then goes back to normal
These can be many things. Are you a diy mechanic, do you have any knowledge of cars and engines? If yes we can talk further, if not best to take the car to a garage and ask them to check for you. For beginning you can change the petrol that you use, fill up with E5 99 from Shell, bp or esso. , Tesco. When your car was serviced last time, what’s the mileage, is it auto or manual? A lots of information needed first , then more answers can be given.
Are you able to buy a cheap code reader and get some codes?  What you're describing could have many causes so they would be useful.
On 10/2/2022 at 8:56 AM, TonyHSD said:
These can be many things. Are you a diy mechanic, do you have any knowledge of cars and engines? If yes we can talk further, if not best to take the car to a garage and ask them to check for you. For beginning you can change the petrol that you use, fill up with E5 99 from shell, bp or esso. , Tesco. When your car was serviced last time, what’s the mileage, is it auto or manual? A lots of information needed first , then more answers can be given.
Manual 28000 miles 2016 plate. never had this problem before it was serviced.full service new spark plugs all from Toyota. But service was done by independent garage.
