Hard to find window regulator
WL1
I need to replace the front right window regulator (electric) on my daughter's Corolla GS 1.4vvti, 2001. Toyota tell me the part is no longer available and I have tried various after market suppliers who say they have an equivalent part but which turns out not to fit. Having taken the door apart the existing regulator may not be original as it is not a Toyota branded one. The regulator is marked BROSE 102 580-XXX, 01-05 101273. It is attached to a Bosch motor marked FPG 12v 0130 821 909. The motor works fine but the regulator has sloppy joints and doesn't move the window evenly.
Does anyone have any ideas where I can find a replacement regulator or get my existing one fixed? Went to National Windscreens who told us not to use the window - but couldn't help with fixing it! Any help appreciated.
I think Brose are a known brand in window regulators; I recall the name from fiddling with a window on a Cavalier I had back in the day. Could be OE.
Going by the vin (RHD UK built car) the part number is
69810-02090
looking at parts for your year and spec
Japan built cars use
69810-12560
UK built, LHD cars use
69810-02100
Hopefully that can give you some direction
69810-12560 is the only number i can find cross-references for, if you fall down the rabbit hole that crosses back to 69801-12170 (6980112170)
