ABS, VCS and brake system lights on my Venza 2009
venza2009
I am seeing ABS, VCS and brake system lights on my Venza 2009.
Rotors & Brake-pad, Brake fluid, Transmission fluid, & shockers and absorbers all changed 3 days ago.
The lights pop up after applying brakes at the speed of 15 or more or the front wheel hit a bump.
Also, my car breaks feel dry when applied and need to push at least 50% of the pedal to get an effective response.
Get the codes read, have the brakes been bled ? if the pedal firms up after 5-6 pumps it more than likely has air in the system
