Inside Door Material Name?
SB1500
Hi there, when working inside a passenger side door,  there is a plastic stretchy kind of sheet. It's pre-cut with holes for wiring and things. And some black, crudely applied bond / seal around the edge.
Can anyone tell me what this material is or where I can order it?
Same with the sealer - the correct stuff that'll stand the test of time
I'll be meddling with the Chinese LEDs and probably will butcher the factory plastic, so wanted to order to be safe..  I wonder if it is an order able part from Toyota?
I know what you mean, that plastic weather seal membrane that's supposed to stop water getting into the car from the window gap!
I'm not sure if there's a more official name...
Heavy duty Polythene would do the job if you cant get something specific.
Hi I believe it's called water shredder sheets that is used as the car door membrane.
B&Q ,Ebay etc will have them.
Hope this helps
Out of interest I searched for Bper's "water shredder sheets" but nothing came up but then found this specific plastic sheet for sealing doors.
Hope this helps
https://www.ebay.co.uk/itm/185239540077?hash=item2b2123116d:g:ThEAAOSw3Gth0UWU&amdata=enc%3AAQAHAAAAoJET0FlrLigzFcHgW1HnTaiuaBJPjVVsh3Iux5M39v%2BprLfTPeoYYvScgjrRQFAPu%2Fqs3op%2FoTqF06qclOVQb70SGuLw3Sz%2BfRfNWtEW%2B8zVS0f0BjVKzLoxNeyICnxzpWKrRFn4tb0JHOLkXIKb7P2QP9Et%2BmyOWlp7I0Hq5xR5lKIiEe3S34wLPR2WcM%2FsqXOV2hdWrBG3YRLBm%2BPq710%3D|tkp%3ABk9SR8iTtJqnYQ
  • Like 3
It’s very important for keeping the inside footwells dry. Fifty years ago I have used an empty plastic fertilizer bag as I had nothing else at the time, sealed it with flooring adhesive for sticking down Lino on floors. It worked perfectly. Probably lasted longer than the car 😁
  • Like 3
You shouldn't need to replace it if you are careful that black gunge is nasty
iirc it's butyl rubber, and it comes as a tape
tbh it's not seen, i tend to use foil duct tape for any tears/rips or to stick the edges down, that will out last the car
https://www.toolstation.com/ybs-thermawrap-foil-tape/p16904
while you're at it, put some sound deadening in the door's, half a sheet inside the door on the outer skin, makes a big difference to the sound of the door and the audio
eg. https://www.caraudiodirect.co.uk/accessories/deadening/silent-coat-starter-set-sound-deadening-damping-isolator-absorber-pack
1 hour ago, DerekHa said:
Hi Derek,
I remember years ago ordering what was then called car door water shredder known today as door card weatherproofing membrane sheet. And it is available off eBay etc.
Opps, I guess I am showing my age with the old name. 🙄
https://www.ebay.co.uk/itm/185568423815
22 minutes ago, Bper said:
Hi Derek,
i think you mean water shedder sheet/film aka polyethylene membrane
  • Haha 2
No your absolutely right it is shedder and not shredder. Did you know that some Land Rover Defender and MG sites still have it under Water Shedder. 😅
  • Haha 1
im just as bad, i mixed up Perko and Dergo the other day - one is a door closer the other is an air admittance valve
  • Haha 1
Do you know the one thing we should all remember when we get things wrong.
At the end of the day we are all human beans. 😅
  • Haha 1
