Climate display issue Corolla e210 hybrid
Zilk55
Also, i do not if this is aloud in this treat. But i like to ask what is the best oil for the Corolla 2.0 185HP engine?
In the past, i changed the oil in my Lexus CT200H to Mobil 0w-20 , because i should be better for start stop engines?
And what interval in Miles of KM do you advice for spark plugs on the 2.0 engine?
Best oil is the one that the car came out of factory with. In your case perhaps 0w16, the brand is up to you. The Lexus you mentioned the oil is exactly that 0w20, the brand down to personal preference. Toyota oils are often made and supplied by Mobile 1, so basically the same oil.
Spark plugs intervals likely to be 60k miles.
It doesn't look like you can't access them from the front, does your AC/heater seem extra loud ? As you are missing the cabin air filter cover
The 3 connectors are on the metal support bar (arrowed), when working on anything electrical, ignition off and/or disconnect the Battery - unless you are doing live testing
oil wise, the M20A-FXS uses Toyota 0w16 - this engine is 150 hp in the Hybrid
The 3 connectors are on the metal support bar (arrowed), when working on anything electrical, ignition off and/or disconnect the battery - unless you are doing live testing
thanks for the answers. Here in Holland we have a specialised brand Kroon, and they have the 0w-16 in store.
Ok, i will unplug one at a time and make pictures if there is anything changing.
Also, i have 2 more questions if i may ask them :)
1-Does anyone know a manual for installing a towbar and the electronics for it? I do not have parking sensors and i do not use the kick open for the tailgate.
2-Speaking about the tailgate. Dont know if a electronic tailgate is standard, but mine makes a Squeak sound. any fix for that? :)
  • 2 months later...
