Engine struggle to start when hot
RHYSF00
Hi all just wondering if i zm on the right path to fix. My fifi struggle to start when hot. It takes a few attempts..it rotates it clicks but no start. This has happened a few times. I looked in haynes manual and it could be the air filter. Can anyone advise
If it's a Corolla 2.0L diesel, it's most likely the starter motor - It's a fairly common issue with the 1CD-TV engine. You either need to find someone who knows how to refurb it with the updated bits, or get a revised one from Toyota.
Otherwise, what have you checked? Most common culprit in general is the 12v Battery is on its way out.
Otherwise, what have you checked? Most common culprit in general is the 12v battery is on its way out.
1.4 petrol
Just a quick upodate for those that are following this thread. i have replace the airfilter with a much better one from Bosch. engine starts lovely from hot and no issues. sounds a bit better aswell.
