Infotainment screen repair
ARAV
I've cracked the front screen (digitiser) on my 2016 infotainment system. Everything behind is working fine, but you can't put in or select data.  Dealer will only replace the whole infotainment unit. Has anyone successfully had their screen replaced after damage? If so, can you tell me where?
Thanks in anticipation!
Hi Alison,
There are auto repair guys that will come out and replace the screen but many require you to remove the unit yourself and send it off for repair.
You can try some of your local car radio audio shops who may be able to replace the screen if you take the car to them or may give you a number for someone to come to you.
If you have someone who has some diy skills if you are unable to do this yourself, I have put a link below. It's USA but shows removal and replacement if this helps. Other videos are there if you scroll through so at least it will give you an idea what's involved. Hope this helps.🙂
https://youtu.be/7yioZO8vUjc
https://youtu.be/jCuI3EAQeMc
its fairly straight forward to swap the screens over, the only screens i have are for the Denso ten models (the digitizer is its own part)
