Trim pieces - part numbers
Woofwoof
12th Gen, My22, hatchback, Icon tech, UK, driver door:
Does anyone have a list of part numbers  for all the interior trim pieces that attach onto the door, including seals, grommets, fasteners, etc.
Where can this be found? and where can replcaement parts be bought?
Thank you.
Good luck with it, I needed a clip for the centre roof console with the lights in, for the RAV.  I've had to measure each of the dimensions of the current one, and get the closest to it.
i can do up to late 2021 parts are mostly the same from 2018
lhd or rhd ?
4 clips for the rav 4 there is a split 12/2021
early - 90467-09240 (red)
Later - 90467-09245 (black)
lhd or rhd ?
RHD - UK spec
I guess the parts are all the smae.
Thank you.
What parts do you require - either internet or main stealer tbh
the door card is held by 4 screws and the rest is clips
I ned the plastic trim pieces for the inside of the window area (inside the door alogside the window) and the rubber seals between that and the door card
Inner weather strip - 68171-02370 (this is the window felt up against the glass that clips to the door and covers the top of the door card
image;s=1080x720
do you mean the trim around the 1/4 light
Weather strip, front fixed window - 68215-12010
there is a plastic piece going up the back side of the window frame section of the door (right next to the B pillar), there are rubber seals alongisde/behind it, plus another rubber seal underneath it which covers the little gap between the abovementioned  plastic piece  and the edge of the door card (namely the section that folds over and acts as the window sill..
When your're sititng in the driver seat, this plastic piece is by your shoulder. This is buy the main driver window that opens and closes.
I need those seals and above mentioned plastic part please
basically the door card, plastic window frame cover, and seals were taken off the driver door and they were not put back together properly, it seems like one of the seals were damaged and nothing fits properly like it did originally.
Hence I want to get new OEM parts.
Thank you so much.
i assume main dealer can provide these pieces
