12V Battery Issues
Empty Sea
I recently returned from a two week holiday to discover that the 12V Battery of my BZ4X was completely dead. I had left the car completely charged at home, but not plugged into the wallbox. In fact, the 12V Battery was so completely flat that when I tried to recharge it using a smart charger, this just set the alarm off before charging could even begin. Thankfully, a call to Toyota Roadside Assistance (AKA The AA), quickly resulted in a restarted the car.
Unfortunately, the media screen then required a numerical 'security code' before it would allow my settings to appear, although I could drive the car itself. The local dealership did not know what this was, but a savvy technician, before he plugged in his computer, asked if I had tried any codes? I had, but not the obvious: '1234'. Everything then sprang back to life.
However, it remains a concern that the 12V Battery should drain within two weeks. It doesn't give much confidence to leave the car in an airport car park whilst on holiday! There also seems to be some confusion about whether to leave the car plugged into a wallbox for long periods. The aforementioned technician thought it was the right thing to do, but page 83 of the manual states: "To prevent the 12-volt battery from being discharged, do not leave the charging port lid open or the charging cable connected to the vehicle."
  • Like 3
Martin, join the 12v club.
  • Like 3
  • Haha 1
It's a common feature of Toyota hybrids and will be standard for EVs too. Our cars no longer need a starter Battery - the traction Battery deals with all that - but they do need a 12v auxiliary Battery to keep the electronic systems alive while the car is switched off and then enable them to be turned on again. This is usually a relatively low capacity battery so it is fairly easy to 'flatten' it if you use 12v systems while the car is 'off'.
The bZ4X manual doesn't appear to tell use what capacity battery they use but you would expect it to be sufficient for the car to be left for two weeks. If you left the car for six weeks you / we ought to expect 'trouble'. Many of us now carry a low capacity Li-Ion jump start pack to mitigate this issue - saves calling out the AA etc.
If you had been using the car regularly beforehand it really should have survived a two week 'rest'. It might be worth checking that you didn't / couldn't have left any accessory switched on during that time. And, if not, it might be worth checking whether there is any DCM update pending for your car - over in RAV-land dodgy DCM software has been know to flatten the 12v auxiliary battery in quite a short time ... 😉
  • Like 4
I suspect Martin left his car at home but there are circumstances prior to leaving a car parked up.
Suppose you are in a car park queue, I am thinking cruise parking, with your car powered off but radio on and frequent powering followed by door opening.
I've had a couple of plug in Prius', and although there were some 12V Battery issues during the lockdown, neither were so unexpectedly problematic.
So now I'm being inducted into the world of Jump Starters - who would have thought these would be a necessity when spending over £50K on a car? And it seems amazing that such technically 'refined' vehicles still rely on 12 V Battery technology first introduced 70 years ago! (Okay, I know that there have been improvements since then.)
  • Like 3
This is a well-known problem. Many people believe the first models of Bz4x and Solterra are suffering from this issue because they were left at the port for months!
I read some forums that some poeple could manage to replace it under warranty.
One example:
  • Like 4
This has been a regular reported problem with the RAV PHEV version especially in colder weather, leaving the car for extended periods.  Many of us carry a small Battery booster in the car so that the car can be mechanically unlocked and the booster connected to just get enough into the 12v system to get the car into the READY mode so that the traction Battery can then charge the 12v Battery.
I also, like other, use a 12v charger in the winer times to top up the battery if I'm only doing short trips or the car is not being used. I have a short adapter cable connected to the 12v battery and simply plug in the charger until it's fully charged.
With the PHEV Toyota recommended leaving the car in the READY mode for 20 mins if the car was not being regularly used.  I guess there must be read across to the bZ4X?
Toyota has to find a solution for this issue:
So this £76 purchase will hopefully give a little peace of mind. But the video from 'Out of Spec' mentions an European software update. Has anyone in the UK had their car recalled for this?
Thats the major update we mentioned in the other topic. Europe received an update and you will need to visit dealer for this to have it done.
"Bz4X Software Bugs, Updates and OTA"
  • 3 months later...
Another two-week holiday. Car had been used for several longer-distance journeys before departing and I left it plugged into the charger. Once again, a flat 12V Battery upon return. But at least the NOCO boost worked a treat!  Surely this is such a fundamental issue that Toyota should address it?
"Not fit for purpose" as far as I'm concerned.  How do manufacturers get away with it?
On 9/18/2023 at 5:05 PM, Empty Sea said:
Another two-week holiday. Car had been used for several longer-distance journeys before departing and I left it plugged into the charger. Once again, a flat 12V battery upon return. But at least the NOCO boost worked a treat!  Surely this is such a fundamental issue that Toyota should address it?
Just run 2 leads to the car one for High voltage Battery & one for the 12 volt Battery that is presuming you parked up at home.
You run a lead from a dedicated charger to the plug for charging the high voltage Battery or in some cases its a normal 13 amp socket with a dedicated plug for the high voltage system on the car.
Strangly not all charging systems are catered for on the one domestic lead.
I never tried but there is a little trick to charge your 12V Battery. Turn the remote climate on using MyToyota apication. They say "once climate control is activated 12 V Battery will be feeded automaticly from lithium ion main batteries" .
Worth to try! Anyone can confirm that this works please leave a comment here.
Had my first experience of a drained auxilary Battery yesterday. Car hadn't been used for about 4 days. I unlocked the door, tried to turn it on and the first error was 'Parking Brake Unavailable' after a few moments fiddling it went completely dead, no display, no error message, couldn't lock the doors. I wasn't at home so had to call Toyota Assist and they, in the guise of Egertons Recovery, turned up within thirty minutes. The very helpful chap connected up his Battery booster pack and the car was up and running within a minute. He told me this is a very common problem on some EVs - mainly Hyundai and Polestar in his experience and getting to the auxilary on a Polestar was a real pain. He couldn't comment on the bz4x as it was the first one he'd been called out to.
All a bit frustrating - shouldn't happen over such a short period and why can't it get a boost from the traction Battery pack if there is sufficient SoC? Why not get an alert in the app along the lines of 'Low SoC in auxilary battery'? I can feel a letter to Toyota coming on - for all the good it will do. Not something you should have to deal with on a car costing north of £50k. I haven't had a flat car battery since my Escort XR3i !
Any recommendations for a portable battery booster? Halfords do one that looks similar to the one the Egerton's chap used --> NOCO GB40 1000A
Chris
I use its little brother Noco Sport GB20 and even that is way more than is necessary to boost the auxiliary Battery. The guy from Egerton's will also have wanted to jump start ICE cars.
Yeah it is a bit lame that Toyota never came up with a solution for this despite encountering the issue with the hybrid Auris!
Currently the Koreans have been the most innovative - If the 12v drops below a certain level it is disconnected and you have to open the car and hold down a button, which re-engages the 12v for just long enough for you to start the car - This means you're much less likely to get stranded.
In their newer EVs, the car will automatically engage the traction Battery and charge the 12v when it drops below a certain SoC.
We alas just need to keep a small jump pack around just in case!
Or drive the car more :naughty:
Weird thing with this is I never had an issue until lockdown and then my CH-R had a flat Battery twice.
The recent Prius also once flagged up a low 12 volt Battery message a couple of days after doing a 200+ mile trip.
I can only assume the 12 volt Battery message was delayed and incorrect as the dealer couldn't figure it out either.
Recently left our BZ4Z at the airport for 11 days. It was fine when we returned. And the first thing we did was raise the powered tailgate to put in the suitcases. In hindsight, should have 'started' the car first.
On 9/25/2023 at 3:40 PM, bZ4X said:
I never tried but there is a little trick to charge your 12V battery. Turn the remote climate on using MyToyota apication. They say "once climate control is activated 12 V battery will be feeded automaticly from lithium ion main batteries" .
Has anyone tried this yet?
An excellent point.
I opened the tailgate after a 16 day trip last month and a week's trip this.
Good idea.  Usual precautions apply.
13 hours ago, ChrisON said:
Had my first experience of a drained auxilary battery yesterday. Car hadn't been used for about 4 days. I unlocked the door, tried to turn it on and the first error was 'Parking Brake Unavailable' after a few moments fiddling it went completely dead, no display, no error message, couldn't lock the doors. I wasn't at home so had to call Toyota Assist and they, in the guise of Egertons Recovery, turned up within thirty minutes. The very helpful chap connected up his battery booster pack and the car was up and running within a minute. He told me this is a very common problem on some EVs - mainly Hyundai and Polestar in his experience and getting to the auxilary on a Polestar was a real pain. He couldn't comment on the bz4x as it was the first one he'd been called out to.
All a bit frustrating - shouldn't happen over such a short period and why can't it get a boost from the traction battery pack if there is sufficient SoC? Why not get an alert in the app along the lines of 'Low SoC in auxilary battery'? I can feel a letter to Toyota coming on - for all the good it will do. Not something you should have to deal with on a car costing north of £50k. I haven't had a flat car battery since my Escort XR3i !
Chris
Have u tried turning the remote climate on using MyToyota apication? This will feed 12V Battery while running the A/C.
I watched this trick on YouTube. It worked for an EV model.
