Xenon Healight Washers and rear parking sensors not working
Vali_RO
Dear all,
Please help me with my 2011 Auris Hybrid:
1. Rear parking sensors are not working( camera does), the wiring is checked in the back and it looks ok.
2. xenon Headlights Washers are not working.
What could it be ? What should I check ?
I will give you also the VIN: SB1KS56E40E029012 it is a LHD since I am from Romania.
Thank you !
Best regards,
You will  need to check fuses to,begin with and then the wires. If not familiar how to best to search Google and YouTube for information and videos. It could be many reasons why you don’t have have these working, difficult to have help online without the car been seen and inspected in person. Perhaps an auto electrician specialist may help.
Good luck
As Tony says check fuses for the washer jet then check for blocked jet If you cannot hear the pump running then you need to check that it is receving a 12 volt supply.
Disconnect power to pump use a voltmeter no voltmeter then use a 12 volt number plate bulb instead of the motor if this lights when you operate the washer jet/wiper switch then time to replace the pump.
Parking sensors first check wiring as in plug connectors for corrosion exspecilaly if its all sensors.
I can live without sensors providing the camera works or take it to a auto electrician for a quoat.
