what is the biggest engine i could fit in a 2010 E15 auris?
33Q
So recently i got my grandmas old car because she stopped driving but i already have a car, so i had the idea of almost like ricing it (for example, tint, black badges obnoxious exhaust system, etc) for example i was watching a video where a guy k20 swapped an old honda jazz (ill put the link to the vid at the bottom) so i thought i might do the same thing. so i thought “why not put a stupid big engine in it” making it like the ultimate meme car. if im being honest im rarely going to use this so i dont mind cutting corners or sacrificing reliability, im just doing this for the !Removed! and giggles.
(this is the video)
The biggest engine Toyota used was a 3.5 litre V6 to create the (Japan only) Toyota Blade Master-G - but obviously a lot more than just the engine was changed:
https://www.autocar.co.uk/car-review/toyota/auris/first-drives/toyota-blade-master-g
https://www.trademe.co.nz/c/motors/review/toyota-blade-master-g-2007-new-car-review
Thanks for the info, do you know where i can buy this, like is it on eBay or do i just have to search online
Thanks alot
9 minutes ago, 33Q said:
Thanks for the info, do you know where i can buy this, like is it on ebay or do i just have to search online
Thanks alot
Probably only from Japan but it’s not just the engine , you need the transmission and ecu’s , immobiliser, suspension is different too.
Basically it’s not worth it unless it is some sort of a special project with media content creation and unlimited budget.
