No British Gas Hive Charger support by Octopus
Louie
Houston we have a problem.
Toyota have a relationship with British Gas who supply Hive chargers (actually ABB Terra 3) and this at present is a free home installation if you  have purchased a Toyota PHEV/EV. This is a fixed period  a promotion.
 I appear to have hit the buffers as our energy supplier Octopus cannot at present support this charger supplied by British Gas. Has anyone had any experience with the British Gas Hive installation and compatibility with their energy supplier's EV tariff ??
I don't want to change my energy supplier to British Gas anytime soon not by any stretch of imagination. I have just purchased an expensive Hybrid PHEV and find that I cannot enrol in a cheap EV tariff really makes me wonder if I have made a dreadful error of judgement.
See:
Perhaps it may have been prudent to  check with Octopus first ...
The other option would be to buy an Octopus charger.
  • Like 3
If you want to use an Intelligent Octopus tariff you will need to install a compatible charger - that's a restriction / limitation imposed by Octopus.
You can use Octopus Go with pretty much any EV charger and still be free to switch to any other supplier without significant penalty or inconvenience.
The world of intelligent tariffs is still very immature ...
So, 'yes' you have made an "error of judgement", but not in your choice of car - rather in you lack of research into EV tariffs ... 😉
Just to add to the above, the EV tariffs divide into two main groups, the first group, are simple time of use tariffs that have a block of off-peak hours at fixed times, there's no connection between the supplier and the EV charge-point or EV, so they typically work with every EV, you just use the timer in the EV or charge-point to ensure it starts charging when the off-peak rate starts. Simple to understand and use.
The second block are the new smart/intelligent/dynamic type tariffs, where the off-peak times can vary each day, so there needs to be some connection/comms between the supplier and the charge-point or EV in order to ensure the charging starts at the right time. These are the ones where compatibility issues pop up because it's all non-standardised as yet. These are much more complex and there's more issues around the reliability of the comms.
You want the simple ones, like the original Octopus Go or failing that, Economy 7 also works.
Thank you guys for all your help.
I have now ordered a smart meter from Octopus to go be used with the Go tariff currently at 9.5 kw/hour and await my British Gas  "Hive" installation.
Sorry a bit late with my reply but I've just gone over to Eon EV tariff and they didn't question which charger was being used.
Which makes sense. I assume that you are on the Eon Next Drive EV tariff?
The Eon Next Drive EV tariff is an 'unintelligent' tariff that simply provides cheaper electricity between midnight and 7:00 am - very much like Economy 7 with peak and off-peak rates. You need a smart meter so that Eon can charge at the correct rate for the time that you are using power, but it is entirely up to you, your car, or your charger when you schedule to charge the car. It doesn't require any communication between the charger and Eon.
