Couple Of Easy Qs
jazzyjc123
hi
doesantone know if the boss kit from a starlet will fit my 2 ? and also has anyone used that foliatec plastic ? is any good and do you have any pics
thanks
j
no - the Boss for a wheel is an MR2 only item due to the horn connector location ..
If its a momo boss then you need code number 7728 which is for 1992 >
The 7715 is for a Rev 1 only as the splines are diferent. Everywhere seems to be out of stock of them at the moment but momo should be getting some from Japan mid September I have been told as I am after one too :)
