HELP!! air conditionaer situation
rodon
hi
i have a 93 celica GTI
2 weeks ago found out that my air conditioner works fine only for the first 10 mins, and then just put out regular air.
2 weeks later had to replace the air conditioner "commpressor" (hope its the right word)--which cost me alot.
2 days after doing that the air conditioner situation with the first 10 min working- happens again
when replacing me the old air compressor (which was burned) the man said that he see a gas leek from the air conditioner radiator.
anyway: can someone help me with this situation?
10x
Back to top
did he change the aircon matrix(radiator)
if he never,then all your gas has escaped again!!!!
and so the compressor controler is switching of the compressor.....B4 it burns out again
mat
he didnt change the AC radiator
is it logical that when the gas is gone still i will have 10 mins of cold air?
if all gas is gone--does it effect the compressor and will make it BURN again?
(so if i suspect that gas is gone i shouldnt use the AC?)?
does it look like an AC radiator problem? which replacing will cost like 500-600 us$.
can only the gas leak at radiator get fixed usually?
10xx
sometimes the aircon matrix /pipework can be repaired.best solution is take it to a specialist and get them to test the whole system.......they will then be best to advise you on the best route of action.........
yep,best not to use the aircon now......
