Ac Problem Lights Flashing
Wittybebop
Hi all I have a ST164 Carlos Sainz Celica and have just had the AC regassed after fixing a small leak in the front I had it regassed but although now the AC compressor starts the AC light stays on for about 5 seconds then the Compressor cuts out again and the light starts flashing if I do this again off and on the same thing happens Stays lit and works for 5 second then cuts out and starts flashing.
Any help would be appreciated.
TIA.
it sounds low on gas once more , take it back where you had it done , the whole point of the flashing light is the low gas warning.but what you say could lead to a faulty compressor / slack belt ???????
When I first had it gassed I dyed the gas to find the leak cured that, now on the regas it should be ok this problem was happening as soon as it was gassed to the right weight so I would assume the pressure is ok in the system.
