Mr2 Pcd And Offsetet
Billy C
  • 4 months later...
Your fitment is right. There's not a 114 x 5 PCD... it is 114.3 x 5 PCD.
You might be alright with a 44 offset. At worst you'll need 2mm-10mm spacers!!! I doubt you'll foul on the calipers or suspension with a 44 offset... especially as they're only a 7J.
Will they not put too much stress on the bearings having that offset? I reckon they will and you'll have to get new wheel bearings like every couple of months! :thumbsup:
Nope... you'd be worse off the other way... i.e. if they're a 30 offset.
A 44mm offset brings the wheel nearer to the car.
