Toyota Active Sub And Sony Mp3 Changer
jonny_brin
I have a Toyota Active Sub fitted to my standard 1-disc CD player in my T-Sport. I want to fit either the Sony CDX-T69 6-disc changer or the Sony CDX-T70MX 6-disc MP3 Changer, will there be any probelms with the sub if I fit the MP3 one or should everything be fine...
(I've read the 'how to' and know I'll need the Connects2 Lead etc)
Cheers...
Not being 100% sure how the toyota active sub is wired in, but it should be ok. If you can get me a pic of the wires in the back of your headunit, then i'll be able to tell you!
Cheers, but I have been told by someone else that this will work, will let you know the results when I actually get it done...
Good good.
I thought that it should as im pretty sure the sub will just be spliced onto the existing speaker wires as to recieve a high-level input which is then amplified. The connection for MP3/CD Changer should then still be free! Im sure you'll be fine! Any questions... just post!
How much is the toyota sub? Is it 60? Thanks
You must be joking right??? It's £200 fitted. £150 not fitted.
I've just got the active sub off eBay for £80 and the toyota tweeters for £15, getting them fitted soon, i may also have a second active sub unit going spare soon, but no cables!
Got my sub at Toyota for £180 including fitting. I got a bit of a discount because of some hassel that I got customer service wise... :thumbsup:
