Painted Caliper
houston
was bored so decided im gonna paint my calipers, but only managed to do one as ive smashed my extension bar, lucky it was as i was tryin to take next wheel off and not puttin wheel back on! will resume play tomorrow!
better than grubby/rusty calipers
very surprising, there wasnt a spot of rust on them, and they were very clean, didnt even have to wipe em down!
was gonna go with silver but spotted GOLD!
just looked at pic and it looks like my cars on stilts!
should have scrubbed em with a wire brush or some wool
helps to 'key' the surface ;)
Any colour looks good, if it keeps the rust away :yes: .
i had some wire wool ready to do it but it really didnt need it, wasnt even slippery! used hammerite to paint it so should stick well
Looking good, Now get those others done ! :P
Redid mine last night as it happens, looks so much better with them painted.
Nice color choice too.
i used spray hammerite, good tip for when using hammerite is to place the tin in hot water for few mins and it makes it easier to paint
You have the same setup as me, crystal front indicators and tinted sidelights :thumbsup:
How easy is it to spray the calipers? I wanna do mine in red.
surprisingly easy, i removed the caliper, just 2 bolts at back, then covered bits i didnt want sprayin with a cloth, make sure you dont spray piston though!
one brake took 15mins including taking the wheel off!
drys in bout 15 mins then put 2nd coat on, good thing bout hammerite is few mins later its dry enough to drive
