Oil Recommendations Please
acf8181
for a '92 UK rev2 n/a with 101k on it.
am thinking mobil 1 10w40 semi-synth is the way to go, agree?
We use 10w40 semi/synth oil. Have done since we got her and had no prob's
:thumbsup:
what brand do you use?
I just put in some Castrol RS Fully Synthetic 0w 40 and I have to say the engine is much smoother and there seems to be slightly more power too. I'd definately recommend going fully synthetic!
well, i went for duckhams 10w40 semi in the end, and car seems to like it. not sure whats been used in it before, but bearing it was owned by a middle aged female teacher it could have been some very cheap stuff. gonna stick to duckhams eveyr 3k now i thinks.
Sorry for not getting back to you earlier we use Duckhams :thumbsup:
and it's cheap enough to replace every 2000 miles :thumbsup:
Site
I use Milers Oil 10w60
Is this any good, its £30 for 5L ?
Should i use 10w60 ?
Its the CFS 10w60 oil !
10w 60 sounds a bit too thick.
Site
Doe's to me aswell :eek:
We use 10W40
oh, well, maybe worth a change then.
was recomended by my local parts shop...got some aditives specialy for turbos apparantly ??
cheers
cheers
I would have thought that thinner oil would be better for tubbys because it will flow round the system faster and provide better cooling for the turbo bearing. I'm not sure what the other tubby owners on here use but 0w 40 is probably about the right viscosity.
I wouldn't use 10w-60, it's simply too thick. (24cst at 100degC)
Your car needs an sae 40 (14cst at 100degC).
The problem with sae 60 is that it causes additional friction which leads to heat and engine wear. Added to this, it wastes power through additional oil drag.
The best option is 5w-40 fully synthetic although 10w-40 semi is adequate, a cost option for want of a better desciption.
Simon
You can use either 10w-40 or 5w-40.
5w-40 is the best option for road use and cold starts.
Simon
Ill be banging in a load of 5w-40 at the next change then, on pay day
What brand is recomended then, any ?
cheers
I have a 92GT which seem's to be getting through a lot of fully systhetic Magantex
10w 40w (requires a top up every 4 wks approx).
Mechanic couldn't see any leeks, car runs fine.
Am I using the wrong grade of oil ?
Cheers,
Gavin
Drop me an email or pm
Simon
Cheers,
Gavin
I think Magnatec is only semi synthetic. Anyway, I've heard stories of engines drinking lots of Magnatec although my car didn't use any when I used it. You're using the right grade of oil, maybe you'd be better trying a different brand.
Magnatec is a semi-synthetic.
I would personally use a decent 5w-40 fully synthetic.
Simon
