Toyota Cab Transformation Project
Elohim
Hello.
I got over a spare part car for my Toyota Cressida Combi 1978. However, it seems like this Sedan car is in good condition, like my Combi, and therefor I have no need for changing any parts at the moment.
Then my friend came up with an idea - to transform the Sedan into a cab; as visualized belowed (quickly made in Photoshop to see the possible result).
Any ideas?
Any speculation of the result?
Any other comments..?
Problems/difficulties of transformation?
:rolleyes:
Check out the pictures....
Possible Toyota Cab
Original Toyota Sedan
Would be a very hard job to do as you would need to strenghen the chassis etc which would add a lot of extra weight to the car and make the chassis a lot more flimsy...
Would look great if you could do it :D
There is one in Japan that has been done (although with very bad taste) In my opinion it would need to be a two door design, with longer front doors. That's a lot of work, and requires a lot of skill...are you up for it?
