Bad Azz Mr2
toyotainnascarin04
Engine:
-CP Racing Pistons .20 overbore
-Crower Rods
-Completely balanced rotating assembly
-Oversized Intake/Exhaust Valves
-Titanium Valve Springs
-Enlarged Intake/Exhaust Ports
-HKS 272 Cams
-HKS Adjustable Cam Gears(2)
-ARP Head Studs
-ARP Main Studs
-HKS Metal Head Gasket
-Solid filled Engine Mounts
Turbo:
-Pro Performance GTBB3037 Dual Ball Bearing Turbo Kit (Swain Technologies heat coated)
-Tial 40mm Extenal Wastegate (Dumps to atmosphere)
-HKS Super Sequential Blow Off Valve
Intercooler: -Spearco w/Spal Fan
Drivetrain:
-Fidanza Lightweight Aluminum Flywheel
-ACT Extreme Stage 4 Pressure Plate
-ACT 6 Puck Clutch Disc
-KAAZ 1.5 Way LSD
-KAAZ Hypoid Gear Oil
Electronics:
-Apexi Super AFC Fuel Computer
-HKS EVC-4 Boost Controller
-HKS Fuel Cut Defencer
-HKS Twin Power Ignition
-Greddy EGT Guage
-Greddy Electronic Boost Guage
-HKS Iridium Plugs
-Nology Wires
Exhaust:
-HKS Dual Dragger
Intake:
-HKS Super Mega Flow
-TVIS Eliminator
Fuel System:
-Custom Dual Feed Fuel Rail
-550cc Injectors
-Supra TT Fuel Pump
-Aeroquip Fuel Lines
-Earl's Fittings
Suspension:
-Spax Adjustable Struts/Lowering Springs
Wheels/Tires:
-Enkie Aegis Chrome (17X8 Front, 17X9 Rear)
-Pirelli P7000 Super Sports (225/35 Front, 245/40 Rear)
Body:
-Kaminari Body Kit (computer paint matched)
-Painted Moldings
I have only put 500 miles on the car scince these modifications were done. All parts were purchased brand new. I have been breaking the engine in on the stock computer and 12 PSI of boost. Once the engine is broke in, the car is built to handle 450-500 HP to the wheels!! I was waiting until the engine was broke in to have it dyno tuned, but it should be producing @350 HP currently. This turbo is extremely efficient and makes more power, at the same boost level, than any other on this application. It spools up very quickly scince it is Ball Bearing (3300 RPM,) and sounds completely nasty under boost!!
sweet
nice engine spec my friend
Strewth, I like the sound of that my friend. Just wondering though, what sort of costs are involved to put all this together.
And is that you in your avitar picture? :thumbsup::thumbsup::thumbsup::thumbsup:
