How Do I Rotate V-grove Tyres
theWizard
I have had my v-groove tyre on for 8 months now and the fronts are more worn than the rear.
Do i change the front with the rear on the same side or with the other side having to remove the tyre from the rim for the latter?
Same side will be fine. :thumbsup: It used to be diagonally, but tyre technology has moved on apace and with directional tyres it`s not worth the hassle.
Thats one of the problems with FWD. the fronts have to do al the work and the rears usually perish before they wear out. You`d be surprised the amount of people who don`t bother rotating tyres any more. Such a waste getting rid of a tyre with 5mm of tread on it. :(
tyres will have an arrow depicting the rotation
