Fault Code Blink Back?
sjrainsford
Hi people!
Does anyone know if you can short a contact on the DLC connector to get the fault light to blink back the code number like you could on the Avensis?
Cheers!
Hi people!
Cheers!
Yep just the same
Let me know the code & i can tell you the area of the problem ;)
I've got a fairly good list of codes, and luckily don't have one at the moment!!
However, I have forgot which connectors you are supposed to short out and the routine for doing it.
Cheers for that!
