Accelerator Relay Gen5
blw
I don't know if this is the same for all Gen 5s, but when I put my foot right down on the accelerator, I can hear a relay clicking, the same happens when I take my foot off the accelerator. It only happens at a certain point on the travel of the pedal, and at the same point on the way back up.
What's causing this?
Thanks!!
Are you sure it's a relay? Could it just be the throttle cable or something?
What area does the sound come from?
You could possibly be hearing the ACIS valve switching.
The sound is coming from under the dash somewhere. It sounds like a relay. What is the ACIS valve?
ACIS - Variable Acoustic Induction System - work's by varying the intake tract length.
:thumbsup:
