Rav-4
fabangel4
Im really keen on getting a Rav-4!
Could anyone let me know what the common problems are?
Whats the best year and milage to go for?
im looking at 1998 onwards at the mo!
i've heard a lot about oil probs has anyone experienced this??
Plus what milage does things start to go wrong?!
Grateful 4 ur help!!
:D :D :D :D :D :D :D :D :D
Not much on the old shape
Abs light on = ABS sensor fault at £130 + each x4 but rare
Frt brake discs can get worn by 50000 mile mark
a few rattles in the back but easy to fix
Make sure the timing belt has been replaced due every 5yrs 60,000 miles £300 job at a dealer
Overall make sure its been serviced when due
Gear change can get worn - the synchro go and make 1st to 2nd & 2nd to 3rd notchy. Although a Rav gearbox cant be rushed anyway without a bit of notchyness
Also make sure it doesnt fall out of fifth gear
Rear shockers slight leakage but only £30 each and 1/2hr per side to fit
Tyres - wear quickly if Dunlop and the 235 size aint that cheap but 215 size u can get for £60 each
Exhaust heatshield comes loose and vibrates but not a big job
Expect 25mpg and poss 30 on a careful run
Sounds dramatic but to be honest one of the more reliable Toyota's on the road
and after all that !
I may know someone selling a 99 3dr special edition Freesport soon ;)
Due to no longer needing a 4wd for £4500 ish
with a new timing belt last month, 2 new tyres last month, new frt brake discs & pads last month and all gear oils,diff oils & oil & filter change last month
:yes::yes::yes::yes::yes:
Has it got good gear ratio??
Also my budget only covers £3000 but every rav i see varies in price so much!! what year and milage would you recommend for that price??
:drool:
:yes:  :yes:  :yes:  :yes:  :yes:
:drool:
Depends on 3 or 5dr
work on a 5dr £750 more than 3dr
N reg 3dr with 80-90k for £3000
