Need Some Help With My Ice
RossP
Right peeps, I should be sorting out my ICE this month, and just want a little bit of advice on it. I want to keep the whole install in my car Pioneer, so it's got to be Pioneer subs and amps etc. So far i have an OEM Pioneer headunit, 4" coaxials in the front and 6x9's in the back. Does anybody have any suggestions as to what i should go for exactly? I mainly listen to R'n'B/Hip-Hop and Trance music. I know that trance music is better with 10", but understand that R'n'B is better with bigger subs.
So i've found these subs for 10"
http://caraudiosecurity.com/shop/product/p...ts_id/3824.html
http://caraudiosecurity.com/shop/product/p...ts_id/3760.html
Probably would need 2 of the bottom ones to make the bass of the first one?? :wacko:
...and these for 12"
http://caraudiosecurity.com/shop/product/p...ts_id/3761.html
http://caraudiosecurity.com/shop/product/p...ts_id/3823.html
I honestly don't know anything about subs and amps, so any help is very welcome. I want a nice install in my boot (bear in mind it's a Vitz/Yaris). It really doesn't matter too much about boot space (because i rarely use it).
As for amplifiers, which pioneer amp would you recommend for the setup of pioneer subs that you choose?
Thanks in advance
Ross
I would probably say this sub as it's a dual 4ohm sub, and if you want 2 then this will be the better sub as you will need a mono amp and wire it in parallel.
I would say this amp,
http://caraudiosecurity.com/shop/product/p...ts_id/3450.html
I would choose these but if I'm wrong i'm sure someone here will tell me
