Vibrate?
N3rd
ok i have a 96 coroalla and it vibrates like hell. Is there anything that is known to go loose on these things that i can tighten. I am a car idiot so put it in laymen terms if u could.
I'm not a Corolla expert but have noticed a lot of posts in the past from currrent owners who have had similar issues, a number of members have posted different ways in which they have fixed this problem.
It easily fixed and shouldn't casueyou to many problems, searching the forum should supply the answer, hope that helps a bit :D
if your whole car physically shakes at speed then you need your wheels balancing and aligning.
If its just a rough ride, look at your suspension and tyre pressures.
no it mainly vibrates when its idling and it comes from the dash in front of the passenger seat. Thanks for all the help.
1. your idle speed is too low.
2. you've got a loose thingy behind your glovebox.
Ok how can this be fixed?
once agian how can this be fixed. Like how can gain access to this.
sorry for newb questions but i just got it tues.
Thanks a ton for the help. :thumbsup:
