Rad Needed...
aob1
Hi All,
I've only just bought my first MR2 and I'm already after parts.... :censor:
I'm looking for a Radiator and (front) fan for a mk2 gti (non-turbo).... it's a late rev1 (UK car).
Any additional advice you could give would also be apprciated... (ie do rads from imports fit UK cars, will a rad from a turbo fit a non-turbo etc etc..)
Found a couple of "How To" links... thoughts please. :huh:
http://spydermagazine.com/2002/Nov/coolant/coolant.htm
http://www.mr2oc.co.uk/modules.php?name=Kn...q.org/co-5.html
AOb1
Your not drunk as long as you can hold to the floor
Welcome to TOC aob1
Regarding the links - I can't access the second one, and I presume you realised that the first one refers to a Mk3 MR2.
I think there's a Rad for sale at the mo on eBay; don't know how price compares with Rogue, you would have to check.
[EDIT]Must post faster - I see that while I was typing Christine & Paul sent you the eBay link[/EDIT]
Regards, Tony
Welcome to TOC aob1
Regards, Tony
:P :P :P
Thanks Tony..
Hadn't actually realised the first link was for a mk3 (... D'oh)
Here's the second link again... pretty sure this is for mk2 (..even the same colour as mine :D )
Thanks for all the other links... anyone know if/where I can get the fan as well ?
thanks again,
AOb1
No probs.
Saw your post on mr20c.
If you're not sure why fan isn't kicking in, then you should test your thermostat & fan before buying a new fan. You can probably get a dealer to do this for you - they'll be able to diagnose the problem for you rather than you buying the wrong bits.
Tony
As above try rogue systems or eBay
and a tip for when you get a new one is fit some mesh in your bumper,
the rad gets a lot of abuse because its so low.
