Wheels + Tyres
Jones~32
I've been told that the correct offset for alloys on a G6R is 42mm to avoid rubbing.
But im not sure what the correct offset is for an AE102, can anybody help me please? :bookworm:
Thanks a lot :thumbsup:
Mike
It should be stamped or cast into the back of the wheel. If you have original wheels take one off and take a look for something that looks like ET 38 or ET 40. The number will be the offset.
i'm sure though, if i remember rightly that the standard offset on mine is ET38. i had a set of wheels with this offset fitted to my last one, and they caught at the back over large bumps. the set i have now are ET42, and don't. maybe if you ask, they'll let you try with both?
Thanks for the speedy reply guys :thumbsup:
I was just wondering what offset id need to get, do you think i could get a set of 17s on one of these?
also lookin at suspension kits, do you know any good places where i can get them from, places ive looked either dont list the car, or seem quite expensive...
Thanks :thumbsup:
Mike
if i can get 17's on mine, you must be able to on those :D im sure there used to be someone on here who had a red GXi with 17's on. maybe do a search?
Cheers, will do :thumbsup:
Mike
Really depends on the width of the rim you are putting on, as the offset will vary between 6.5J and 7J rims.
