Lowing My Gxi
OriRacer
Ok i'm lowering my GXI this weekend with 40mm drop springs. Front of the car was done and dusted within an hour but now i'm stuck. I can't seam to undo the ball joint bolt on the anti-roll bar linkage. I've tried WD40, and vice grips but still no luck just keeps on turning.
:ffs: so I have nice slamed car at the front but sticking up at the back
PLEASE HELP!! two hours turning bolts and still no joy!
Those rear links can be real tough.
Best not to undo them, leave em as they are and change the springs that way.
Use compressors, undo the top 3 bolts and the top single bolt, then wiggle out the shock till you can take off the top mount and take off the spring.
It worked with my e10!
thanks,
Kamran
Do the front tyres rub with it lowered?
what offset wheels have you got on yours?
Cheers
Mike :thumbsup:
Dont worry once I have it all done i'll be able to put up some pictures and give you all the information you need. But just now she is sitting on bricks  :huh:
:lol: Fair enough
Good luck with getting it sorted :thumbsup:
Mike
