Hows This For A Turbo But Will It Work? Im Stumped
XscurrenltD
I have been offered this turbo for my Curren XS Ltd engine typpe is a 3afe, 2L is this going to A. fit and B. Actuly be able to be run with out serious mods to my engine can some one help i have limited time to make my discission
Hybrid Garrett TA34 turbo with0.58A/R T/Hsg and 56.5mm T04E Compressor
wheel and front.360 Degree thrust kit, full loop turbine piston
ring.T/Shaft Hiflow and backcut,50mm exducer,10mm blade height,etc.T/Hsg
is T3 type flange,so should bolt straight to manifold.This is internal
wastegate type.Or you could leave wastegate closed and use external
type,etc.This should be good for,350-370HP at the flywheel (260-275KW)
Cheers Guys and Girls
