Gt Turbo Starlet
elmixador
hi guys
im looking for part numbers for the following,
1. piston rings-standard
2. mains and big end bearings-standard
3. gasket kit
its for a toyota starlet gt turbo 1991/2 4E-FTE L4 1331cc DOHC 16 Valve Turbo EP82-AGMQY.
If any body can help me out i would appreciate it.
If you're after Genuine Toyota parts, then just go down to your local dealer armed with the FULL model and chassis number from the VIN plate on your car.
They can look up any part for your car ( import or not ) with this information.
I regularly buy parts for my Sera with no problems this way.
I don't know what the aftermarket places are like in your part of the world, but over here all of these could be sourced at a decent motor factors place too.
Alternatively you could try the guys at toyotaownersclub.co.uk .
Good luck with the engine........sounds like you're having fun with it !
hi guys
3. gasket kit
Answers :
1. 13011-11132
2. Mains : (need to specify marking - "1", "2" or "3") 11701-10012-01, 11701-10012-02 or 11701-10012-03 ... 5 in total.
Big-ends : (need to specify marking - "1", "2" or "3") 13041-11030-01, 13041-11030-02 or 13041-11030-03 ... 4 in total.
3. 04111-11104
Cheers,
P. ;)
