Automatics Questions / Compass Problem
mimic
I'm quite new to automatics, in my Prado there is a button 2nd start and ect power. Thing is the manual is in Japanese.
Could someone please let me know why andwhen these are needed to be used ? Using 2nd start does it reduce fuel consumption(don't know much about vehicle stuff).
Another problem I got is the instrument panel, the one with the compass, tachometer, etc ... the compass is an electronic one and only show N N N N all round, anyone know what to do with that ?
Mimic
The ECt button is like a sports mode on the gear change , it will hold the gears longer giving more power and torque , good for when towing uphill .
On the compass you should have a reset button , if you have press it and the drive round in 360 deg , this should help it correct itself .
2nd start on autos is used in snowy or icy weather. The higher gear should stop the vehicle from slipping.
  • 3 years later...
I have Prado TZ 2001 model and the compass recently show N N N N all round. any idea how to fix it ?
Much appreciated.
