Vibration
Milliebean
I need :help: I have a 1995 Camry, and it vibrates. It vibrates once I reach about 55-60 mph and up, and it also vibrates when I brake. Any ideas on what this could be from?
Sounds to me like your wheels need balancing (I experienced this with my Civic... when I had one :D ). Maybe there's a dent on one of the rims, or one of the tires are slightly warped. Small lead weights might have to be stuck to the inside of your rims to balance the wheels.
I just recently got new tires, and they have been balanced and rotated, and I also just got my car aligned. UGH! :ffs: Do you think it has to do with my brakes? Like my rotor or discs??
Its posible that a wheel weight has fallen off giving you the vibration, get you front wheels done again as its only since you had you tyres fitted!....
Dan
