Side Steps
jasonsinclair
They look alright but I would be a little sceptical before seeing more photos as they look to have some kind of polished look to them which is not consistent with aluminium.
See if they have more photos of RAVs they have fitted them to.
Not a bad price mind you, have genuine set of toyota ones fitted to mine and they really set the car off so defintiely worth pursuing as an optional extra.
Paul
Hmmm...the chrome tube style look better , but will rust in time :( , the Aluminium eBay ones,don't look so good, but should look better for longer (in my opinion) :D .
I have seen these on a friends car and whilst they are not as good as the toyota version, are a third of the price and make the car look good. They have an anodised finish and come with 4 non slip pads that stick on in front of each door opening. My only criticism is that there is no anodising where the aluminium extrusion is cut on both ends and although the end caps cover this, the metal still corrodes.
Also as they are dead straight, they do not follow the line of the sill (toyota versions do)
:thumbsup:
