Can Someone Help Me Please!
hoho15
is it a RW cd?
if so it needs to be 'finallised' before you try to use it, the TOC or 'table of contents' is the the first thing the player looks for and is basically like an index/map that tells it where to look for the tracks/info on the disc
PM Jaxx he's the audio guy :thumbsup:
jerry!!
Ha Ha you are quick Rob :thumbsup:
jerry!!
thing is the cds worked b4 like 15mins ago and then it just stoped and started saying TOC error and no cd i put in will work
no cd works then its the player, mite be worth trying a lens cleaner, failing that its died
i think its dust inside im gunna have 2 try a lense cleaner cos its happend b4 a few times thanks alot jaxx! what kind of lense cleaner?
Just the normal cd cleaner. The one with the little brushes on the cd that should do it mate. They normally have got the liquid to put onto the brushes as well :thumbsup:
jerry!!
as my man jerry says, available from HMV and the likes, about 5 quid i would expect
No problem buddy just hope that it works for you. Theres nothing worse that a CD head unit messing around :ffs: After all you've got to have tunes in the car man :lol:
jerry!!
Dont worry mate the CD cleaner should cure the problem ;)
jerry!!
