Rattle
Tegan
My mk1 has had a rattle for some time now - i presumed it was heat sheild rattling - havent been able to locate the source though
It only does it at 1500 revs and then stops when i rev it higher
I heard somebody saying that mr2's are well known for developing a rattle but that its got something to do with bearings? :unsure:
Now i dont know enough to know whether this is true or false
does anybody else have a similar rattle - i know most on here are mk2's but has anyone heard of this?
surely if this wasnt just a hea sheild then the rattle would be happening all the time and not just at certain revs?
T x
Hi tegan
Is it like a vibrating sound from inside the car? And the higher the revs it dissappears?
jerry!!
OR the back wheel could be loose.........Joke !
The rattle is more than likely a heat shield, it only happens at a certain rev range, as thats the metals size and shape osilating frequency (i sound really sad now !!! :D :P ) ie the right vibration speed to keep it vibrating.
any faster / slower vibrations just dont keep it constantly rattling
I wouldnt worry too much as said !
OR....Remove the heat sheild (and drive to see if it still happens) then tighten them up and see what its like then
hi
its most likely a heat shied bent or loose as mine was doing the same a few weeks ago.........revin it 2500 it rattles and higher it stops.... but got it sorted from a garage and it was bent and loose and they bent it back and tightened it and it was fine. :thumbsup:
I have a rattle... it behind the dash tho... grrr... somewhere behind the driver's side air vent methinks... it irritates me as it starts up about 3-4k revs....
Sounds like yours is a heatshield thing Teegs... :thumbsup: good luck with that
Hi tegan
jerry!!
no jerry it does sound like its coming from outside the car - i hear it more when i open the window etc
its too 'tinny' to be a a bearing. just REMIND ME when im available!
Okay i will do :P
But thanks for the replies everyone - i had myself thinking i was looking at an expensive bill :unsure:
but the noise is very tinny and it sounds like a common problem - its just so annoying :angry: people look at you like your car is knackered! :rolleyes:
