Sloppy Suspension On 91 Corolla
Obeychap
Hi.
I have a 91 Corolla DX and I was hoping there is a way to tighten the stock suspension.
The suspension is so sloppy that if I sit on the front or rear side fender(on top of the coils), the car nearly touches the ground.
And it would help a lot whenever I back up off the driveway without having the car hit the ground.
Are there anyway to fix this problem without having to replace the suspension?
quite honestly.....NO if its knackered it meeds replacing otherwise its only a bodge.
You could install ride assistors found in towing/caraven places, they're like an airbag that sits in the coil and you inflate it, but it wont cure the problem properly, your money would be better spent on some replacement springs.
