Brakes On Rev 2 Tubby
Markturbo
hi i know my rear brake on the drivers side is stuck on,
and im not sure about the other side just wondering do you think i need to change the caliper or is there a common fault with the mr2 brakes which causes them to get stuck on
do you think i should just replace them then
if so where the cheapest place to get them i have been looking at the prices on fensport
or is there a good upgrade you can do which dooesn't cost to much can rev3 brakes fit a rev 2 and are n/a ones diffrent from the tubby ones
rev3 = rev2 .. it's the rev1's that are teeny tiny :) .. and there are no differances between Na or Turbo ..
The caliper re-con kits are about a tenner from "brakes international" ..
