Ps2/dvd Players In Yaris's
oliross
I wanna put a ps2 in my yaris and get a couple of screens in the sunvisors, how would i go about doing this, and how can you put a new head unit in the glovebox so i can run subs. Seen these screens advertised wondered if they are any good???
tgincar.com
Shaz's boyfriend Darren has a set up in his T-Sport.... plus there has been loads of previous threads about this too!
Give a PM to Blaze! :thumbsup:
To power the ps2 you need a inverter (150w is enough) which plugs into the cig lighter.
I bought replacement sunvisors with 7" screens built in off eBay, its the cheapest place if you wanna buy screens!
And with the glovebox, all i did was cut a wooden surround and slotted it in.
The glovebox is quite small mind and the dvd player i have is smaller than standard DIN size so not sure if you'd have to cut a big hole at the back of the glovebox to get a h/u to fit!!
:thumbsup:
vmail Posted Yesterday, 04:12 PM
  must be a bit hard to change tracks
Na it wouldnt be if you think about it. You are only going to have the dvd player running if you have a passenger watching it or if your stationary. Plus a lot of them come with Remotes and you could always move the IR receiver by extending its cable if you wanted to :P
