Will The Tte Springs Fit On A T Sport?
evil_yo
hello all
Will the TTE springs fit on the T Sport?
Toyota says they wont because the Tsport has a different set up and are not compatible?
please advise
cheers
Ah so it was you that bought them!!
Yes, they should fit the T-sport without any problems. Well that's what I can remember, someone correct me if i'm wrong
Yes they will, 'cos I bought the ones that Kimi had on hers.
:D
A
They're TTE springs for all Yaris AFAIK.
Think that they'll lower your T-sport by another 30mm.
Someone else can hopefully confirm that though.
They will lower ANY Yaris 30mm! :thumbsup:
How many times do we need to go over this! :rolleyes:
Earpl, sort a sticky for this! :yes:
I started on an explanation of that and stopped thinking, "No Alan, don't go there..."
:lol:
A
I thought they lower a TS and lower models 30mm. However as the Tsport chassis is what makes it lower as standard it will be lowered by springs by 30mm but will look lower than lower spec models. However doesnt the SR already have a 20mm drop as it is on lowered springs as standard so therefore surely by buying these 30mm TTE spring you would lower it 10mm lower than on its stock lowering springs?
I think thats closer :P
O and i think the tsport is on stiffer springs but without a drop (chassis being what makes it lower) but possibly also with uprated shocks? (know the shocks from a standard yaris rear dont fit a tsport rear)
Edited by Woody27
