Engine Swap - 1g-fe To 1jzgte Help!
nitrousFiz
Hi every1,
I have a Toyota Mark II 1998 GX100 with 1G-FE Engine. I want to swap this engine and put a 1JZ GTE twin turbo 280hp engine, ECU & auto transmission.
This is the biggest mod to my car as of yet. I need to source/find the engine, ecu & transmission from Japan and import it to Bangladesh.
Can you guys please help me find engine exporters from japan?
nitrousFiz.... :)
An easy half way house would be the 1G-GTE :thumbsup:
Does you 1G have the later cast engine mounts with the fluid filled rubbers?? if so as far as I know a 1JZ with mkiii supra mounts and brackets should fit right in with no subframe work!
