Found This 2 On The Japanese Auction Scene!
jaxx
FTO headlamps, highly modded GT widebody, pants ferrari/bus rear lights, not bad bar the latter if you ask me
Well let me be the 1st person to say that its !Removed! repulsive... and that rear! :!Removed!: :ban:
I agree - worst example I have ever seen - a complete abomination :ban:
pretty nice, if it had the rear light surround painted yellow to match and had all red rear lights would look much nicer IMO
what site was that on ???
i do like the front 3/4 shot the back end is pretty dire though
..tosh, seen it on the japanese auctions :yes:
fronts ok.. back is not so nice
requested the info pack from the auction, hopefully get some detail shots :yes:
Found some great tips on repairing it :thumbsup:
Tools
File - to remove any excess material, be it from production or from cutting the pieces out
Craft knife - same as the file but I found it easier to use, although I do have wounds from its use.
Modelling glue - plastic model glue is designed to bind two pieces of plastic together, by a process only describable as plastic welding or fusion. This glue does take time to set, its not superglue. It is not designed to glue anything else
Clamps - invaluable to hold things together while they set. They're like a second pair of hands. they also speed up the building process.
Flat paint brush and paint pallet - The type of paint brush is that you see in most model shops and the type you get in most model packs have a rounded bristle. When applying pressure to the bristles such as you do when painting the bristles spread out, this causes an uneven distribution of paint and makes detailing much harder. The ideal brush has a flat bristle end which doesn't spread out when pressure is applied. A pallet is useful to mix paints and blot the paint brush.
plastic-cement.jpg ;) :thumbsup:
