Another Ice Question
RossP
if it is designed to run before external amps, then yes.
Kenwood KGC-9044 11 Band Graphic Equaliser
Features
* High Voltage Pre-Amp output (4v) for connection to external amplifier
* Subwoofer pre-out with 4 Step LPF
* Subwoofer output level adjustable
* RCA Front/Rear pre-out with 9 step HPF
* Flip down removable faceplate with carrying case
* DIN size in dash mounting
* 4 Colour LCD display with white LED back light
* Factory Preset EQ curves
* Programmable EQ curves
Looks like it should then....
