Hilux Pickup
ACE
I purchased a 1995 Hilux pickup 3 months ago and have replaced front axle hub seals and rear brakes. The front axle has contiued to leak oil into front hub and then onto wheel, any suggestions and is this a normal problem ? Also the rear brake drums are getting very hot (steaming) after fitting new shoes and drums although they appear to release properly. I have checked all adjusters and all appear to be working ,any ideas
Welcome to TOC
Steve (Tubby Turbo) would be the man with the Hi-Lux answers....................he is one of the best known Hilux owners on these forums :thumbsup:
A good tip would be to post your query on the 4X4 section of the TOC forums.
Hope you get the answers to your problems
