Where To Get Parts From
VoRN_182
Ive jut bought a Starlet turbo, obviously being an import im going to struggle for parts.
Am I correct in assuming a toyota dealer wont supply any?
Im after a new hose which runs between the turbo and the entrance to the intercooler as its split. I imagine this is a common fault as I had the same problem with my Celica last year
Toyota will be able to supply you if you give them chassis no/model code or even a reg no. Failing that Samco from Fensport or Demon Tweeks etc :thumbsup:
There are plenty of people running Starlet Turbos in the UK, and there is a good aftermarket part supply for them too. Getting anything won't be a problem.
AND, Like Daz said, Toyota will supply any part for your car - import or not. They even supply parts for mine !!!!
everytime summat brakes just buy an upgrade:P get onto toyotaownersclub.com im from midlands too :) theres a guy called dave on that site an he sells most the stuff you'd need. also the user "petbeema" for performance parts etc
