Clutch Problem
gblack1984
hi me again my clutch is slipping when i'm in fifth gear. Does any one why this is? do i need a new clutch, air in the clutch fluid? cause i'm not to sure
How is it in the other gears?? if you try drive off with the handbrake on or a brick under your wheel will it slip in first??
