Noisey Reverse Gear
echomaniac2
HI EVERYONE. DOES ANYBODY HAVE A NOISEY REVERSE GEAR WITH THEIR 5 SPEED MANUAL BOX? I HAVE WHAT WE CALL IN NEW ZEALAND, AN ECHO T-SPORT. SAME AS THE YARIS T-SPORT. SOUNDS LIKE A BEARING NOISE, WHICH STOPS THE FASTER I GO IN REVERSE GEAR? NOT SURE IF IT'S THE CUT OF THE GEARS, OR A PROBLEM INTERNALLY. WOULD APPRECIATE YOUR VIEWS ON THIS SUBJECT. CHEERS.
Don't most cars whine in reverse?
Thats what I thought..............................after all, you don't travel very far (or fast) going backwards do you? :unsure:
There is a definite bearing noise there. I just hope none of the teeth on the gear are damaged...Thanks for your replies .
