Dash Lighting...
paddyboy15
Hi all...
i've been looking on previous posts of how to replace the dashboard lighting in a Yaris T Sport but keep getting confused! :wacko:
Is there a simple way of just replacing the bulbs/leds with blue ones and if so, at what cost!?!?
The easy way is to put something blue over the L.E.D's.
Or remove the green rubber off them and paint them with bulb laquer.
The standard green L.E.D's are sealed into a plastic unit, I doubt you would get them out. Plus you'd have to find out what voltage was running through them and find the right L.E.D's to match.
