Aircon For Ae92
BTEX
Think you will find most models had it available as an option... except for this country. Seen 2 cars fitted with it. Would need the complete system... ie all pipes, wiring, compressor, condensor and evaporator.
About the only thing that would make these cars better than they are.
you could source the parts from an ae111 as the engine compartment is the same the only differance is the cooler unit in the car but im sure something can be made for this. dont forget you need all the wiring and the a/c amplifier this is situated on the cooler unit
